Edit by Admin; Keine Doppelposts! Editierfunktion nutzen, Beiträge zusammengefasst!
Habe die gesuchte Antwort schon selbst gefunden:
The difference between a PG or a TH350 is 3RD gear if you plan on going over 55 mph and staying under 3000 RPM when doing so I would go with the TH350 If this is a strickly drag strip car there are some old boys out there that can build you a hell of a mean PG for that.
