Hier der Artikel von shBox:
The low coolant sensor is a most common cause of complaint. If it gets dirty, it may cause the lamp to come on when the coolant level is actually ok. Sometimes it fails and no amount of cleaning will fix it. The sensor is only connected to the lamp on the dash. It does not report to the PCM and no DTC's will be set. Because of this, some people choose to simply unplug the sensor to get rid of the annoyance without having to fix it. Unplugging it will make the lamp go out, but you will have to monitor the coolant level yourself. As critical as the coolant is to the LT1, having it working makes sense.
If the light seems to come and go, make sure the level in the remote reservoir is proper. Normal operation of the cooling system often causes coolant from the radiator to overflow into the remote reservoir. As the engine cools down, the radiator creates a vacuum and pulls this coolant back into the radiator. The piping from the neck of the radiator to the reservoir must be air tight for this to occur. Since these cars are getting older, it is not uncommon to get a small leak in the pipe that goes under the battery. Acid wears away at the pipe until it makes a hole. Even a small hole is enough to cause problems. A telltale sign is a small amount of coolant under the right front of the car after it is parked a while. Usually, only taking out the battery will reveal where it is coming from, because it slowly drips on the splash panel underneath and may travel along to another area to drip off.
If the lamp is coming on for no apparent reason (you have verified coolant level is fine-that is, checked the level in a cold radiator and verified you have the proper level in the remote reservoir), you have just a few choices:
Clean the sensor and try it again
Replace the sensor
Unplug the sensor
Hier soweit der Link:
SHBOX (Best Side for LT1 Stuff!!!)
Soweit also alles ok, warum die Lampe nun doch an ging ist mir ne Rätsel....
